WIFI UBD für Iphone
AW: WIFI UBD für Iphone
muss das irgendwie an das Auto angeschlossen werden? Wenn ja, wie?
@alFanta: Du kannst Dir ja erstmal die "lite" Version runter laden und testen. Die ist umsonst!
Hier mal die Hardware die du dazu brauchst, ist ein ODB Wlan Key.
Link zum Hersteller: http://www.devtoaster.com/products/rev/
Rev's Hardware Companions
Rev communicates with your vehicle via its physical OBD-II port. Interfacing with this port requires an OBD-II hardware device that supports the 802.11/WiFi interface on the iPhone and iPod touch.
DevToaster supports a variety of devices serving a variety of needs.
Features
All devices supported by Rev have the following features:
  • Small size—easy to tuck anywhere in your vehicle.
  • Works with Rev right out of the box! Just setup a connection with your iPhone or iPod Touch.
  • Powered directly from your vehicle. No batteries or cigarette adapters needed.
  • Blazing-fast wireless communication over 802.11/WiFi.
Supported Vehicles
Perhaps our most-asked question has been "is my vehicle supported?". We cannot answer that question exactly because each vehicle model is set up differently by its manufacturer.
In the United States, all vehicles sold after 1996 (1998 in Canada) were required to have OBD-II support. That means if you're driving a 1996 or later vehicle in the United States (1998 in Canada), your car is virtually guaranteed to be supported. The number of metrics supplied by the vehicle may vary, but you are certain to get the important ones required for the operation and evaluation of the vehicle (speed, RPM, etc) as well as support for reading and clearing trouble codes.
If your vehicle was made before 1996, or if you're just not sure whether or not OBD-II is supported by your vehicle, check with your local dealer or service garage.
Supported Devices
The following manufacturers are proud to support Rev.
Kiwi Wifi
by PLX Devices
Product info: Kiwi Wifi
Ordering: Buy Now
Based in: United States (California)
Ships: Worldwide
Description
Kiwi Wifi is a plug and play wireless device measuring only 2.75 x 1.25 x 0.6 inches. Kiwi Wifi comes attached with a 6 ft OBDII cable for easy installation. It is compatible with 1996 and later vehicles. Connecting to your iPhone/iPod touch is made by 802.11a/b/g connection in adHoc mode.
ElmCanII-WLAN
by CarCode-Muller
Ordering: CarCode-eShop
Based in: EU (Germany)
Ships: Worldwide
Description
Rev's original hardware partner! The first OBD-II/WLAN product on the market. Manufactured in Germany under strict European Union standards. OBD2/EOBD interface for all protocols and WLAN (TCP/IP) computer/iPhone connection, with a maximum bandwidth of 54 Mbps. Includes all cables and protection bag.
OBDKey WLAN
by KBM Systems
Product info: OBDKey WLAN
Ordering: OBDKey Store
Based in: EU (United Kingdom)
Ships: Worldwide
Description
OBDKey WLAN is a vehicle interface providing a WiFi/Wireless LAN/WLAN radio interface for devices that have a WiFi compatible system. A single unit design with no cables or mechanical connectors.
Note: DevToaster no longer directly sells OBD-II hardware. Please refer directly to the manufacturers for sales and support. If you encounter any troubles obtaining support from those companies, contact us and we'll help work it out.
If you previously purchased a CarCode-Muller ElmCanII-WLAN from DevToaster, we still provide support. E-mail support@devtoaster.com for assistance.
Usage Considerations
Adding WiFi-broadcasting hardware to your automobile is probably a paradigm shift for most auto-enthusiasts. We ask that customers consider the following when purchasing WiFi automotive hardware for perminent installation:
  • Leaving the module plugged in at all times will draw a small amount of power from the battery. Check with the manufacturer for exact power consumption.
  • While the module is on, it broadcasts an open (by default) unsecured wireless network. There is WPA and WEP encryption support on the module, but these are far from perfect security protocols.
Please consider these items in the context of your neighborhood parking conditions, and driving frequency.
Ah Super Danke Winni! Jetzt hab ich das auch auf der HP gefunden ;-)
Och und ich dachte bei der Rubrikenwahl schon jemand hätte ein feines App fürs z•racing•team gebastelt ... :M
Ich dachte es wäre speziel fürs Racing Team :B
das iphone bleibt in der Box und man kann wärend der Fahrt in der Box die Daten beobachten......
Moin,
das ist ja obercool. Hat´s denn schon jemand ausprobiert. Ich bin ja fast schon bei der Bestellung.
Sascha
wer redet hier von bluetooth? wifi = w-lan....die ODB2 adapter emulieren nen kleinen accesspoint, der sich mit der rev2 software verbindet und so die daten über w-lan in echtzeit streamt...
daher wird das wohl auch gehen wenn das iphone in der box ist.
hab damit auch geliebäugelt - jedoch sind über ODB2 nur feste bestandteile klassifiziert und nicht alles was für mich von interesse ist auslesbar....
daher gibts wohl bald ne direkte möglichkeit bei der ECU abzugreifen ;)
ach, sag bloß Bluetooth geht nicht soweit...
Das sollte ja der Scherz an der Geschichte sein. Denn nach der Topographie der Nordschleife würde sicher nicht ständig Kontakt bestehen können.
Moin,
Ich finde das ganze auch HÖCHST spannend!! Was soll denn der ganze Spaß kosten? Da die Teile recht klein sind, sollte sich das Equipment sehr elegant verbauen lassen. Muss mir das ganze mal näher ansehen. Das wäre was für mein 2011er Ringtool.
Moin,
konnte nicht wiederstehen und habe mir das Kiwi WIFI für 150$ bestellt. Versand kostet leider auch noch. Die App ist für 31,99€ zu haben.
Mal sehen wie´s funktioniert.
Sascha
Und sind die Teile angekommen?
Hast Du es schon getestet?
Bin sehr an einem Bericht interessiert.
