Chiptuning S62 engine Z8
Epicurus
14 Mai 2006
A friend of mine wants to 'chip'tune his (2003) Z8. Only the chip, and nothing more. He aims at +20hp and +25nm, is this reasonable ?
Does anyone on this forum have any experience with 'only' chipping ? I understand that there are a few companies that produce such chips, Dinan and Nowack are the names that come up when you search the Internet for this....? Any advise ??
AW: Chiptuning S62 engine Z8
hi,
there are several threads discussing this. But in short some advice:
Do it ONLY with a dyno pull BEFORE and AFTER "chipping" Most advertising is very optimistic and in the worst case, you can get less hp than before.
If you compare the prices of some companies who sell only some kind of chip with Nowack, you can see that for a little more money you can get:
- Dyno Pull before and after chipping
- correcting the rev limiter a little bit, so you get an better way from one gear to another
- removing of the v-max limitation
Anyway, much fun with the car :t
Winni is right, Nowack is a good place for this, lots of experience with the S62 in both M5 and Z8.
Nowack offers several packages depending on what your friend wants to do, everything from simple chipping to extensive engine modifications.
Tolle und seeehhhrr günstige Gelegenheit:
35 PS für 89,95 $ na wenn das kein Angebot ist :d
speziell für Z8:
2001 BMW Z8 Performance Parts
Blow Off Valve (1)​
Z8 Performance Parts - Buy BMW Z8 Performance Parts
BMW developed the Z8 Performance Parts and engineered to the technological state of the art, it's a sports car that's about sensations as well as power. The sensation of sitting low just ahead of the rear axle, looking out over an endless bonnet that hints at the muscle of the 5 litre V-8 beneath. Of irresistible force as its 400 power the aluminum body forward. And of being sheltered in luxury while revealing in a driving experience that leaves you yearning for more.
Z8 Performance Parts add horsepower to your car, making it faster from 0-60 and the quarter mile. Every modification you do to your car make the car more enjoyable to drive. Z8 Performance Parts can add as little as 1hp and up to hundreds of hp depending on what type of upgrade you choose from. Some Z8 Performance Parts such as chips can be installed in minutes adding horsepower and torque. Performance Pulleys are also a good horsepower upgrade to add to your list of upgrades. Turbo Timers are essential for turbo’s during summer time conditions when your engine can be really hot.
Surge Performance Chip
Brand: CustomDetails:
  • Add up to 35 Horse Power
  • Add 20+ Ft.LBS. of Torque
  • 1-4 MPG Savings
  • More power to tow
  • More low end torque
  • Faster 0-60 MPH times
  • Faster 1/4 and 1/8th mile track times
  • Faster Acceleration at all RPM
  • Up to 20% quicker throttle response time
  • Smoother shifting (Automatics only)
Installation: Comes with 1 Set of Step by step, Easy to read installation instructions
What you will receive
1 Surge Performance HP Module
(Installation time is approximately 5-10 Minutes at the most)
LIFETIME WARRANTY with no HASSLES!
And last upto 35+ HORSEPOWER( The bigger the engine the more HP gained).
How the module works
With the new fuel injection systems, we noticed a common problem among all vehicles with fuel injected systems. The Fuel system runs too rich from the factory. When race cars are built to the finest specifications, they must be TUNED correctly. If the engine is not tuned correctly, the engine can either run to lean, causing engine damage, or run to rich, which in return wastes fuel and sacrifices performance. However, through extensive research and development we have found a secret in the automotive performance industry. We have found how to produce horsepower and save you fuel.. Our module will modify the AIR/FUEL ratio mixture to allow optimum performance. Air + Fuel = Combustion in the the cylinders. Combustion = horsepower. Our kit will allow you to have your vehicle properly tuned using our state of the art module. The best part is, you will not need a mechanic to complete the installation. With our easy to read, step by step installation instructions you will be able to complete the installation in 5-10 minutes at the very most! In fact, the installation is so simple, you will not even need any prior car experience to install our module.
Frequently Asked Questions
Question: My vehicle is turbo or supercharged, will this work on my vehicle?
Answer: Sorry our modules do not work on turbo/supercharged vehicles.
Question: Will I be able to install the module by myself or will I need a mechanic?
Answer: You will be able to install this module by yourself! You will not need a mechanic to complete the installation. We include easy to read, Step by step installation instructions to complete the installation by yourself in less than 10 minutes and you will not need any prior experience. You will NOT be cutting, soldering or crimping wires to complete the install. The module is a simple plug and play installation. If you can plug a lamp into the wall, you will be able to complete the installation!
Shipping Cost: $9.99Shipping Info: Usually ships within 5 days.Listing Price: $199.99Selling Price: $89.99
