I get a harmonic high pitched hum (pretty loud) on the freeway at 70+ MPH (faster is louder) when I keep the accelerator pedal in a position to maintain speed (not accerlerating, not let off pedal to decelerate). It's like the drive train is in equilibrium and something is loose. Because accelerating tightens it up and using engine decelerating tightens it up in the other direction and the noise goes away.
I've tried changing out the diff oil and machining E36 Rougue diff cover a little so it doesn't touch Randy Forbes pendant mounts.
Going to replace rear wheel bearings and overhaul axles next.
Anyone have any advice?
Thanks!
Thanks!
