ercman
There is a 3-core, pre-twisted LiFY 0.25 mm² cable used for computer applications that I used.
It works perfectly.
It works perfectly.
That's the solution I can't recommend, except you will repair it several times. He definitely shortens the wires.I saw this on YT,
Could you please send me a direct link to the exact type wire I need please?Wow, exactly the mess I was describing!Stiffened and shortened wires cause them to break right at the microswitch.
On top of that, the idiot cut off the white strain relief clips because his dirty work had become too thick.
2-core speaker wires are absolutely the opposite of 3 flexible LiFy 0.25mm² wires.
Similiar examples of messy repairs and how it should be rebuilt:
------- Dachstörungen Klappdach -------
Good luck.
That is the material I used for repairs:Could you please send me a direct link to the exact type wire I need please?
Yes, it's as easy as you've already disassembled it.Would it be as simple as just plugging the new unit into the 5 connector and remounting?
Ui,21. März 2017
An welcher Stelle ist dieser Bruch?![]()
Ist da nicht was gebrochen? Ich meine die Stelle links unterhalb der rechten Zugentlastung....Bei einem Freund eine interessante Entdeckung gemacht:
Nach teurer Vor-Reparatur war das Schloß wieder defekt:
- 2 Drähte verkürzt gelötet
- 1 Draht (sw) lang belassen
- Äußere Hülle entfernt
- Zu kurze Leitungen neben die Zugentlastung gelegt
- Per Schrumpfschlauch alles versteift
- Alle linken Drähte wieder kaputt, sw und gn durch
- Auf der rechten Seite ebenfalls Hülle und Zugentlastung entfernt
- Alle 3 Drähte angebrochen
So geht's nicht!
Zu allem Überfluss hat ein Idiot (Werkstatt?) durch Einsprühen von Motorrad-Kettenspray (klebriges Zeugs) in die Flipper-Öffnungen versucht, das früher schon mal defekte Schloss wieder gangbar zu machen!
Do you have keyless entry? Then do put the key away, or it is wanted behavior that the boot opens without unlocking it explicitly. Also, the other locks should still be locked.Hello everyone,
Just a quick update and another question!
The new mechanism finally arrived from BMW. 5 wires re-connected, boot light working fine.
Closed boot, vehicle latches and soft close works!! As expected from a new part I guess.
However, one issue I now have, and that is it won’t lock! It latches and soft closes fully, but when I press key fob, doors lock but the boot can still be opened.
Is there something I’ve missed? I’m pretty certain I seated all the cables fully.
The car hasn’t been driven for over 10 days due to awaiting the part. Could a low battery be an issue (even though the doors lock).
Any help as always greatly appreciated.
